============================================================== Guild: wafer.space Community Channel: Information / questions / Cadence PDK? After: 02/28/2026 23:59 Before: 04/01/2026 00:00 ============================================================== [03/25/2026 14:40] chaask Does the wafer.space GF180 PDK have a Virtuoso compatible version. I am trying to do some analog design work, and i am comfortable inside Virtuoso. So just wondering, if we have that option. [03/25/2026 17:09] nmz787 I haven't seen any [03/25/2026 17:09] nmz787 the only DRC seems to be klayout [03/25/2026 17:29] 246tnt Wouldn't that be distributed by Cadence directly ? [03/25/2026 17:30] 246tnt I know for sky130 open pdk, Cadence is the one ditributing the matching PDK. [03/25/2026 17:30] 246tnt It's still subject to NDA and such so no-one else can distribute it ... [03/25/2026 19:37] chaask I dont think cadence version is opensource. but generally mpw vendors or the foundry supply the closed source pdk under nda. is that possible with us. [03/25/2026 19:38] chaask will our mpw partner also be able do that @Tim 'mithro' Ansell . [03/25/2026 19:43] mithro_ wafer.space doesn't care how you create the GDS but we don't supply access to any proprietary PDKs. Your GDS also needs to be 100% clean by the wafer.space platform, not whatever the cadence or any proprietary PDK says. Wafer.space also does not support waivers from customers. [03/25/2026 19:46] mithro_ Some people have access to a mostly compatible Cadence PDK through agreements with other entities and have successfully taped out. As well, GF will *not* respond to requests for the PDK without other relationships with them already. [03/25/2026 19:46] chaask thanks tim. [03/25/2026 19:47] mithro_ I'm unclear if Cadence tooling is able to load the open source file formats. They are old enough / simple enough they might work with a bit of work. [03/25/2026 19:49] mithro_ Btw wafer.space also doesn't provide any direct support for tooling - open or closed. If you need technical help in creating designs (with whatever tooling), the design help page has a number of companies willing to provide paid support services. {Reactions} 👍 [03/25/2026 20:48] nmz787 my experience also is that the foundry provides the PDK, with support for any tools they expect users will want. I have never heard of tool vendors supplying a foundry PDK component [03/25/2026 20:49] nmz787 for something like DRC, I don't think this is possible without some translator which surely Cadence/Synopsys isn't making for working with klayout [03/25/2026 20:49] nmz787 OASIS and GDS are industry standards, so of course closed-source tools support them [03/25/2026 20:50] nmz787 APR techfiles are mostly ASCII with grid definitions (pitches, CDs, spaces) so a translator is likely easier to code (I suppose even for AI) ============================================================== Exported 17 message(s) ==============================================================
