Hi, Iām about to start preparing a PCB What is the recommended way to include your chip-on-board-wire-bonded-pcb in a KiCAD project to have the labeled symbol in the schematic and your designed footprint as a placeholder in the layout? While I can open/edit your project, Iām in question on how to include it properly.
Thanks @Tim 'mithro' Ansell
Hey @Meinhard Kissich
Looking at this, theres a lot of work I need to do to make this more accessible.
In https://github.com/wafer-space/chip-on-board-wire-bonded-pcbs/tree/main/scratch/motherboards/motherboards you can see a couple simple examples.
See them in kicanvas
Kicad's symbol sharing is beyond atrocious. I recommend just opening the file and saving the symbols to your library however you see fit. And if you don't care about adding to your library, you can just copy/paste or whatever else suits you.
The default pads just pass the pad number from the default template, and are also aliased to Tiny Tapeouts pin conventions as well.
Hope that helps
@Andrew Wingate Could you comment on whether the pinout of the CoB board is stable?
I believe at least Hirosh's and Meinhard's PCBs already depend on it.
Yeah, I've already said this to @asic destroyer and others I believe.
@Meinhard Kissich we should not be having any changes to the COB for at least this run.
What we have should be considered stable and we will discuss further improvements possibly for run #2
