============================================================== Guild: wafer.space Community Channel: Information / questions / Chip-on-Board Module as Component After: 01/31/2026 23:59 Before: 03/01/2026 00:00 ============================================================== [02/09/2026 08:43] meinhard Hi, Iā€˜m about to start preparing a PCB šŸ™‚ What is the recommended way to include your chip-on-board-wire-bonded-pcb in a KiCAD project to have the labeled symbol in the schematic and your designed footprint as a placeholder in the layout? While I can open/edit your project, I’m in question on how to include it properly. [02/10/2026 05:57] mithro_ @Andrew Wingate - You seem to have ideas / opinions on this. [02/10/2026 05:58] mithro_ @Meinhard Kissich - I believe you should probably ask in the #cob channel and look at the information there. [02/10/2026 06:05] anfroholic Thanks @Tim 'mithro' Ansell Hey @Meinhard Kissich Looking at this, theres a lot of work I need to do to make this more accessible. In https://github.com/wafer-space/chip-on-board-wire-bonded-pcbs/tree/main/scratch/motherboards/motherboards you can see a couple simple examples. See them in [kicanvas](https://kicanvas.org/?repo=https%3A%2F%2Fgithub.com%2Fwafer-space%2Fchip-on-board-wire-bonded-pcbs%2Ftree%2Fmain%2Fscratch%2Fmotherboards%2Fmotherboards) Kicad's symbol sharing is beyond atrocious. I recommend just opening the file and saving the symbols to your library however you see fit. And if you don't care about adding to your library, you can just copy/paste or whatever else suits you. The default pads just pass the pad number from the default template, and are also aliased to Tiny Tapeouts pin conventions as well. Hope that helps {Embed} https://github.com/wafer-space/chip-on-board-wire-bonded-pcbs/tree/main/scratch/motherboards/motherboards chip-on-board-wire-bonded-pcbs/scratch/motherboards/motherboards at... Wire bonded chip on board PCB designs. Contribute to wafer-space/chip-on-board-wire-bonded-pcbs development by creating an account on GitHub. 2026-02_media/chip-on-board-wire-bonded-pcbs-66450 [02/10/2026 06:06] anfroholic @Tim 'mithro' Ansell It would be super cool if there was a way Kicanvas could post a view of the board in the preview like the other link above. [02/10/2026 06:09] mithro_ @Andrew Wingate - Maybe ask an AI if it can make that happen? šŸ˜› {Reactions} šŸ˜‚ [02/10/2026 06:09] anfroholic I don't have enough tokens [02/10/2026 07:06] meinhard Great, thanks for the support šŸ™‚ [02/25/2026 16:58] meinhard @Andrew Wingate After some refinement I'm quite happy with my board now. The Chip-on-Board repo mentions _WiP_. Should I wait for sending the board to manufacturing or is the Mezzanine connector pinout (i.e., [1]) already settled? [1] https://github.com/wafer-space/chip-on-board-wire-bonded-pcbs/tree/main/74pad-70pin-mezzanine [02/25/2026 21:31] mithro_ @Meinhard Kissich - Depends on how much your board costs and how much you care about if you have to do a respin. {Reactions} šŸ‘ [02/26/2026 07:21] meinhard Okay šŸ™‚ [02/27/2026 07:32] mole99 @Andrew Wingate Could you comment on whether the pinout of the CoB board is stable? I believe at least Hirosh's and Meinhard's PCBs already depend on it. [02/27/2026 07:35] anfroholic Yeah, I've already said this to @asic destroyer and others I believe. @Meinhard Kissich we should not be having any changes to the COB for at least this run. What we have should be considered stable and we will discuss further improvements possibly for run #2 {Reactions} šŸ’œ (4) ============================================================== Exported 13 message(s) ==============================================================
