Information / questions / Connecting analog pin in librelane flow
Last night, I thought I'd try taking @Matt Venn's R2R DAC he just submitted on TT 0p3 and add it to TinyQV. I've got the macro in and the digital inputs + ground are connected OK (could probably do with buffers on the input, but one thing at a time). However, librelane won't route the output from the DAC to the analog pin - possibly quite sensibly as in general it probably shouldn't touch analog things. How should I deal with making that connection? I guess I could add it manually to the gds after the librelane flow has finished, but that seems not ideal. Can I add a step to the flow to describe the connection? Or can I just tell the router to connect it somehow? My repo is here, see the dac branch: https://github.com/MichaelBell/ws02-tinyQV/tree/dac
TinyQV for Wafer Space run 2 on gf180mcuD. Contribute to MichaelBell/ws02-tinyQV development by creating an account on GitHub.
Interested to see how you solve it!
This is an issue I encountered last run as well, give me a minute to remember the fix
9:16 a.m.
Librelane does not like that the pad’s layout does not have a port named "PAD". That’s it.
9:16 a.m.
That’s all I did. Copy the files for the analog pad and define a port named "PAD" in magic
9:17 a.m.
Multi-project die. Contribute to AvalonSemiconductors/ws-submission-2025 development by creating an account on GitHub.
9:18 a.m.
Its not even different electrically. The analog pad just provides a straight connection to the outside, the ports "ASIG5V" and "PAD" are electrically shorted, but LibreLane needs "PAD" to exist.
9:18 a.m.
Otherwise it goes "whoa, this is useless!" and optimizes it out, since all it sees is a cell with only an input and no output (I believe)
Leo Moser (mole99) 2026-06-12 9:21 a.m.
The issue is that OpenROAD's detailed router does not route any pins with the SPECIAL attribute. This makes sense for power supplies, as they are handled by a dedicated pdngen call.
9:22 a.m.
Here you can see that ASIG5V has SPECIAL set to True.
9:22 a.m.
Looking at the LEF for gf180mcu_fd_io__asig_5p0.lef, I don't see the SPECIAL attribute set for ASIG5V. However, OpenROAD probably sets it when making the bondpad a BTerm (top-level pin) with place_io_terminals.
9:25 a.m.
I had a similar issue with HeiChips: in IHP, the bondpads are separate from the I/O cells and place_bondpad also makes the pin SPECIAL. My solution (workaround) was to edit the LEF to add a second port for the core-facing pin of the I/O cell.
9:25 a.m.
afaik sky130 doesn't have this issue since the I/O cells have separate ports for bondpad and core side.
I noticed that SPECIAL appeared in the def on the OpenROAD.PadRing step, and suspected that might be the reason the router ignored it
9:27 a.m.
But couldn't work out where that was coming from (or even if it was sensible to try and avoid it!)
Leo Moser (mole99) 2026-06-12 9:29 a.m.
iirc @tnt recently found a workaround that doesn't require to edit the LEF file? It involves placing a macro with two ports, which is essentially just a short, next to the core-facing pin of the I/O cell.
9:30 a.m.
However, Tholin's solution is also fine.
Yesh, I putting a small macro doing the split connection which works better for me than editing the pads in the PDK :
  • No need for modifying PDK
  • Because the short is in a separate block with just that in it, it actually doesn't mess with full LVS/GDS check, both the "schematic" and "layout" side of that block will have a single 0R resistor in them, no ambiguity.
  • That also allowed me to connect all the split Metal2 traces on the core side, join them together for better connection and bring them to Metal3 where I needed them, avoiding me to have to deal with via at all when routing them 😅
9:38 a.m.
Ends up looking like this :
Cool, that sounds like a good solution. I assume I can find that in the TT gf0p3 project?
But the routing is still done manually though ODB scripts, I don't leave it up to the auto-router.
9:40 a.m.
You can't find it anywhere, that's WIP which is not pushed publically anywhere yet.
9:42 a.m.
But the macro is 2 squares of metal with via between them 😅 just positioned right where it needs to be. (edited)
Leo Moser (mole99) 2026-06-12 9:45 a.m.
And if you want to leave it up to the auto-router, you can now add NDRs directly via the LibreLane config 😉 https://github.com/FPGA-Research/heichips25-tapeout/blob/d555bbc58aad6cc54e0bc9ce81b75936db2df0d8/librelane/config.yaml#L253
👀 1
Thanks all, I’ve got tnt’s solution working and it’s building with no errors 🙂
Exported 25 message(s)
