Information / questions / Constant inputs in SDC
Between 2025-10-31 11:59 p.m. and 2025-12-01 12:00 a.m.
So, this would be more of a "nice to have" for my project to make the results of top-level timing analysis look a bit neater, but my die is a multi-project die, with 5 input-only pins providing project selection through a multiplexer. However, during top-level timing analysis, STA considers changes on the project select inputs in-between clock ticks. As the chip is designed to have those pads permanently bonded/wired to power or ground according to the desired selection, they should be considered constants for the purpose of timing analysis. But how do I codify this in my .sdc file?
Leo Moser (mole99) 2025-11-07 5:44 a.m.
You can ignore a timing path using set_false_path.
Exported 2 message(s)
