============================================================== Guild: wafer.space Community Channel: Information / questions / Failing Hold Checks After: 11/30/2025 23:59 Before: 01/01/2026 00:00 ============================================================== [12/03/2025 19:56] trev5514 Has anyone been able to pass timing for hold checks on an 11MHz+ design? I have done everything I could think of, yet the corners still end up failing. The path is always pad -> reg nothing else. I've tried these settings: PL_RESIZER_HOLD_SLACK_MARGIN from 0.1, 0.3, 0.5 even 0.7 and none seem to make a difference (I do get less hold errors but all still fail) I've tried PL_RESIZER_ALLOW_SETUP_VIOS and set_input_delay -min 0, .5, 1, 1.5 Any ideas? [12/03/2025 20:08] mole99 Perhaps an unbalanced clock tree? You can view the clock tree in OpenROAD GUI. [12/03/2025 20:12] ravenslofty sure; I've passed hold checks on a 60MHz design :p [12/03/2025 20:12] ravenslofty I do often need to ECO some hold buffers in though [12/03/2025 20:18] trev5514 With the exception of the right spot which I'll look into it looks very balanced. {Attachments} 2025-12_media/Screenshot_2025-12-03_at_3.17.55_PM-42947.png [12/03/2025 20:19] trev5514 Do you manually place them in? Did you change your input/output delays or do you use the templates default 0 for min? [12/03/2025 20:21] ravenslofty read `54-openroad-stapostpnr/summary.rpt` to find the failing corners, then look at `54-openroad-stapostpnr//min.rpt` to find the failing paths, and then [follow the docs](https://librelane.readthedocs.io/en/latest/usage/using_ecos.html) [12/03/2025 20:21] ravenslofty it's manual in that you have to point the tooling at the cell you want to insert a hold buffer for, but there's no physical placement or such {Reactions} 👏 (2) [12/03/2025 20:25] trev5514 Thank you, I have been looking at those corners but I didn't know about the ECO step! [12/03/2025 20:26] ravenslofty (the downside of having a 60MHz design is that I have basically given up on meeting slow corner setup without major cheating) [12/03/2025 20:27] trev5514 My original target was 90MHz and now I'm just trying to get any passing. I'm currently failing 10MHz... [12/03/2025 20:28] ravenslofty are you using the 9-track libraries? [12/03/2025 20:31] trev5514 Whatever the default one is. [12/03/2025 20:33] ravenslofty 7-track. Try adding `STD_CELL_LIBRARY: gf180mcu_fd_sc_mcu9t5v0` to your `librelane/config.yaml` {Reactions} 👍 [12/03/2025 20:35] trev5514 I'll give it a go after I try ECO. Surely 10MHz is possible with the 7-track? At this point - what do I know haha! [12/03/2025 20:56] trev5514 @Lofty Did you ever run into unconnected ECO pins after the eco step? [12/03/2025 21:08] trev5514 Looks like the disconnected pins are pwr/gnd: eco_buffer_0/VDD, eco_buffer_0/VNW, eco_buffer_0/VPW, and eco_buffer_0/VSS [12/03/2025 21:12] greg.hashtag.9468 What does your I/O connect to? If it's not actually driven synchronously alongside your clock input. You may be able to further relax the timing. With a `input_delay -min 0` you're telling the tools, the external i/o arrives with the clock. So it tries to add 4ns of delay to ensure a leaf in your clock tree. [12/03/2025 21:14] trev5514 Everything is synchronous with the clock input. [12/03/2025 22:38] polyfractal (oof, did not know about ECO or 9T stuff either. probably would have saved a lot of agony fussing with settings 😅 ) [12/03/2025 22:39] trev5514 Maybe, ECO isn't working for me still and neither is the 9T [12/03/2025 22:50] trev5514 For anyone that runs into the ECO issue: "+OpenROAD.DetailedRouting": "Odb.InsertECOBuffers" "+Odb.InsertECOBuffers": "OpenROAD.DetailedRouting" I haven't confirmed yet, but I added the Odb.InsertECOBuffers step but I didn't add the routing after which likely left the ECO buffers unconnected. ============================================================== Exported 22 message(s) ==============================================================
