============================================================== Guild: wafer.space Community Channel: Information / questions / gf180 tapeout template drc error After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/21/2025 19:40] xintingjiang_36756 When I run the DRC check using the provided GF180 project template in the Nix shell enviornment (with only the pad rings included) encountered about 104 errors. One example is shown in the attached image. I wanted to confirm whether we are expected to debug these errors ourselves, or if they may be related to the provided pad-ring macros. Thanks! {Attachments} 2025-11_media/image-7DAE6.png [11/21/2025 23:56] mithro_ @Leo Moser (mole99) [11/22/2025 07:16] mole99 @Evansika That looks like an error I had already fixed. Could you please verify that your PDK is up to date? [11/22/2025 16:00] xintingjiang_36756 Yes, it passed when i updated the pdk. Thanks! {Reactions} 👍 [11/24/2025 03:40] xintingjiang_36756 Oh i found that i still got 11 antenna violations with the empty template with pad frame. Are these critical? {Attachments} 2025-11_media/image-2E7D8.png [11/24/2025 07:34] mole99 @Evansika Did you update your template repo as well? The antenna violations in the default template have been fixed with this PR: https://github.com/wafer-space/gf180mcu-project-template/pull/24 [11/24/2025 20:06] xintingjiang_36756 Thanks for the heads up. Now I update the template as well as the pdk repo. But now I am encountering the following DRC issues(LVS and antenna errors are clean). I am running on my M4 MAC in the nix environment, when I launch the nix shell, there were 2 skip and 1 fail see attached, I am not sure if this has something to do with the drc errors. {Attachments} 2025-11_media/image-F9244.png 2025-11_media/get_attachment_url-ADECE.png [11/24/2025 22:18] _luke_w_ I also get magic/klayout XORs on my macbook but not on my Linux desktop [11/24/2025 22:18] _luke_w_ for now just working around it by using the Linux machine when I care about DRC. Is that an option for you OP? [11/24/2025 22:19] _luke_w_ Also all of the magic DRCs I get are just complaints about filler cells being placed on top of themselves. As far as I'm aware this is harmless and other people have reported it too. [11/25/2025 03:23] xintingjiang_36756 yes it works on linux. We will run on Linux when it comes to drc. Thanks! [11/25/2025 08:09] mole99 The difference between macOS and Linux is unexpected and strange. But then again, we're running LibreLane `dev` with updated OpenROAD, so some issues might be expected. @Evansika Could you open an issue in [gf180mcu-project-template](https://github.com/wafer-space/gf180mcu-project-template) so we can keep track of this? {Reactions} 👍 ============================================================== Exported 12 message(s) ==============================================================
