============================================================== Guild: wafer.space Community Channel: Information / questions / high res poly resistor option After: 02/28/2026 23:59 Before: 04/01/2026 00:00 ============================================================== [03/20/2026 06:35] christoph_36502 Which of the options for high res poly resistors is enabled for these runs? There is 1000ohm/sq, 2000ohm/sq and 3000ohm/sq and the note in the documentation says it can only be one of them. [03/20/2026 09:57] mithro_ {Attachments} 2026-03_media/image-7F6AD.png [03/20/2026 10:05] mole99 @Tim Edwards Do you know if the runs at Efabless used the same configuration? [03/20/2026 10:27] mithro_ @Leo Moser (mole99) - I believe I got that config from Efabless {Reactions} 👍 [03/20/2026 13:28] rtimothyedwards_19428 Yes, it's all what's defined in `gf180mcuD` or else I would have to make another PDK variant. [03/20/2026 16:11] christoph_36502 Ok so it's the 1000ohm/sq version available both in 3.3V and 6.0V if I read this correctly. Thanks everyone 👍 ============================================================== Exported 6 message(s) ==============================================================
