Information / questions / How to retrieve run error message from plateform.wafer.space?
Clyde Laforge 12/03/2025 14:27
Seems like my design is failing some checks on the online plateform (or the plateform itself is failing) with Processing Logs === SYSTEM ERROR - See error_message field === RETRY #1: Automatic retry after error === SYSTEM ERROR - See error_message field === RETRY #2: Automatic retry after error === SYSTEM ERROR - See error_message field === RETRY #3: Automatic retry after error === SYSTEM ERROR - See error_message field === Is there a way to get more information? I do not see what the "error_message field" refers to
Tim 'mithro' Ansell 12/03/2025 14:31
@Clyde Laforge - SYSTEM ERROR means the precheck failed to run correctly.
14:32
Well, looks like I broke the prechecks.....
14:32
column shuttles_shuttle.max_slots does not exist LINE 1: ...ttle"."description", "shuttles_shuttle"."status", "shuttles_...
Leo Moser (mole99) 12/03/2025 14:32
For now you can run the same precheck locally: https://github.com/wafer-space/gf180mcu-precheck
Precheck for wafer.space MPW runs using the gf180mcu PDK - GitHub - wafer-space/gf180mcu-precheck: Precheck for wafer.space MPW runs using the gf180mcu PDK
Clyde Laforge 12/03/2025 14:33
Yes! nix-shell currently compiling 🙂
Tim 'mithro' Ansell 12/03/2025 14:33
I just need to restart the task worker so it picks up the db structure change.
Clyde Laforge 12/03/2025 14:34
Thank you for looking into this @Tim 'mithro' Ansell
Tim 'mithro' Ansell 12/03/2025 14:37
@Leo Moser (mole99) - Now it's one for you I think
Leo Moser (mole99) 12/03/2025 14:38
Yes
14:39
assert id_cell.bbox() == qrcode_cell.bbox() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ AssertionError
14:39
@Clyde Laforge Did you place this QR code instance?
14:40
It seems the bounding box is not as expected.
Clyde Laforge 12/03/2025 14:41
I reused the one that originally came from the pad ring from a couple weeks ago, but maybe there was some update to it?
Clyde Laforge
Clyde Laforge 12/03/2025 14:46
Checked and my design seems correct and up to date, with a valid gf180mcu_ws_ip__id cell at 0,0.
Leo Moser (mole99) 12/03/2025 14:48
Is the instance directly after the top cell in the hierarchy?
14:49
Can you confirm the size of the boundary layer is 142.8, 142.8?
14:49
What is your ID?
Clyde Laforge 12/03/2025 14:50
Yes
What is your ID?
TRID
Clyde Laforge 12/03/2025 14:51
Yes
Leo Moser (mole99) 12/03/2025 14:52
Can you provide me a link to your layout? :)
14:52
(Can also be in private.)
Clyde Laforge 12/03/2025 14:53
Project template for wafer.space MPW runs using the gf180mcu PDK - Scafir/gf180mcu-project-trident-gf180-teststructure
👌 1
Leo Moser (mole99) 12/03/2025 15:04
I can trigger the same issue. Will look for a solution.
Leo Moser (mole99) 12/03/2025 15:13
Your database unit (dbu) of the layout is 0.05um. The dbu must be 0.001um and all geometry must be on-grid 0.05um.
15:14
You should be able to easily scale your whole layout :)
15:14
(And I can add a new check to the precheck)
15:17
[16:17:19] ERROR Subprocess had a non-zero exit.step.py:1383 [16:17:19] ERROR Last 1 line(s):step.py:1388 [Error]: Database unit (dbu) is not 0.001um. Now that's a better error ;)
Clyde Laforge 12/03/2025 15:27
Very nice, thank you!
👌 1
Exported 30 message(s)
