============================================================== Guild: wafer.space Community Channel: Information / questions / How to retrieve run error message from plateform.wafer.space? After: 11/30/2025 23:59 Before: 01/01/2026 00:00 ============================================================== [12/03/2025 14:27] scafir Seems like my design is failing some checks on the online plateform (or the plateform itself is failing) with Processing Logs ``` === SYSTEM ERROR - See error_message field === RETRY #1: Automatic retry after error === SYSTEM ERROR - See error_message field === RETRY #2: Automatic retry after error === SYSTEM ERROR - See error_message field === RETRY #3: Automatic retry after error === SYSTEM ERROR - See error_message field === ``` Is there a way to get more information? I do not see what the "error_message field" refers to [12/03/2025 14:31] mithro_ @Clyde Laforge - SYSTEM ERROR means the precheck failed to run correctly. [12/03/2025 14:32] mithro_ Well, looks like I broke the prechecks..... [12/03/2025 14:32] mithro_ ``` column shuttles_shuttle.max_slots does not exist LINE 1: ...ttle"."description", "shuttles_shuttle"."status", "shuttles_... ``` [12/03/2025 14:32] mole99 For now you can run the same precheck locally: https://github.com/wafer-space/gf180mcu-precheck {Embed} https://github.com/wafer-space/gf180mcu-precheck GitHub - wafer-space/gf180mcu-precheck: Precheck for wafer.space MP... Precheck for wafer.space MPW runs using the gf180mcu PDK - GitHub - wafer-space/gf180mcu-precheck: Precheck for wafer.space MPW runs using the gf180mcu PDK 2025-12_media/gf180mcu-precheck-B88AF [12/03/2025 14:33] scafir Yes! nix-shell currently compiling 🙂 {Reactions} 👍 [12/03/2025 14:33] mithro_ I just need to restart the task worker so it picks up the db structure change. [12/03/2025 14:34] scafir Thank you for looking into this @Tim 'mithro' Ansell [12/03/2025 14:37] mithro_ @Leo Moser (mole99) - Now it's one for you I think [12/03/2025 14:38] mole99 Yes [12/03/2025 14:39] mole99 ``` assert id_cell.bbox() == qrcode_cell.bbox() ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ AssertionError ``` [12/03/2025 14:39] mole99 @Clyde Laforge Did you place [this QR code instance](https://github.com/wafer-space/gf180mcu-project-template/tree/main/ip/gf180mcu_ws_ip__id)? [12/03/2025 14:40] mole99 It seems the bounding box is not as expected. [12/03/2025 14:41] scafir I reused the one that originally came from the pad ring from a couple weeks ago, but maybe there was some update to it? [12/03/2025 14:46] scafir Checked and my design seems correct and up to date, with a valid `gf180mcu_ws_ip__id` cell at 0,0. [12/03/2025 14:48] mole99 Is the instance directly after the top cell in the hierarchy? [12/03/2025 14:49] mole99 Can you confirm the size of the boundary layer is 142.8, 142.8? [12/03/2025 14:49] mole99 What is your ID? [12/03/2025 14:50] scafir Yes [12/03/2025 14:50] scafir TRID [12/03/2025 14:51] scafir Yes [12/03/2025 14:52] mole99 Can you provide me a link to your layout? :) [12/03/2025 14:52] mole99 (Can also be in private.) [12/03/2025 14:53] scafir No, it's fine, it's source available (hopefully with a proper open source license soon ^^'): https://github.com/Scafir/gf180mcu-project-trident-gf180-teststructure/blob/3f02c0f9c702dd272a04e1c97542253af30421cf/klayout/top.layout.filled.gds.gz {Embed} https://github.com/Scafir/gf180mcu-project-trident-gf180-teststructure/blob/3f02c0f9c702dd272a04e1c97542253af30421cf/klayout/top.layout.filled.gds.gz gf180mcu-project-trident-gf180-teststructure/klayout/top.layout.fil... Project template for wafer.space MPW runs using the gf180mcu PDK - Scafir/gf180mcu-project-trident-gf180-teststructure {Reactions} 👌 [12/03/2025 15:04] mole99 I can trigger the same issue. Will look for a solution. [12/03/2025 15:13] mole99 Your database unit (dbu) of the layout is 0.05um. The dbu must be 0.001um and all geometry must be on-grid 0.05um. [12/03/2025 15:14] mole99 You should be able to easily scale your whole layout :) [12/03/2025 15:14] mole99 (And I can add a new check to the precheck) [12/03/2025 15:17] mole99 ``` [16:17:19] ERROR Subprocess had a non-zero exit.step.py:1383 [16:17:19] ERROR Last 1 line(s):step.py:1388 [Error]: Database unit (dbu) is not 0.001um. ``` Now that's a better error ;) [12/03/2025 15:27] scafir Very nice, thank you! {Reactions} 👌 ============================================================== Exported 30 message(s) ==============================================================
