============================================================== Guild: wafer.space Community Channel: Information / questions / InOut unsupported error After: 11/30/2025 23:59 Before: 01/01/2026 00:00 ============================================================== [12/15/2025 20:52] chvsnaveen12 Has anyone encountered this error before. My entire project is in Systemverilog. 6. Executing SLANG frontend. src/chip_core.sv:18:17: error: direction 'InOut' on inlined port connection unsupported inout wire VDD, ^ src/chip_core.sv:19:17: error: direction 'InOut' on inlined port connection unsupported inout wire VSS, ^ src/chip_core.sv:38:39: error: direction 'InOut' on inlined port connection unsupported inout wire [NUM_ANALOG_PADS-1:0] analog // Analog [12/15/2025 21:00] mole99 If you use slang, did you also set: `SLANG_ARGUMENTS: ['--keep-hierarchy']`? {Reactions} 👍 (2) ============================================================== Exported 2 message(s) ==============================================================
