Information / questions / IO selection
Any reason to use the CMOS input buffer vs schmitt ? Any reason to go for slow slew ?
Leo Moser (mole99) 11/15/2025 13:10
Is this a general question or one related to the template?
  • The schmitt buffer can be used for the clock to prevent false switching/glitches. But I'm not sure if it's absolutely necessary.
  • Slow slew: for EMC reasons for example
It was more in general but in the context of GF180. Like I don't see any case where you wouldn't want a schmitt input for instance. AFAICT from the spec document, it's same delay, same input load, so why not use it all the time ?
Leo Moser (mole99) 11/15/2025 13:18
Good point. Perhaps because it does not switch at the mid-point, which could be a problem for some applications? Just guessing 🤷‍♂️
Exported 4 message(s)
