============================================================== Guild: wafer.space Community Channel: Information / questions / IO selection After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/15/2025 13:05] 246tnt Any reason to use the CMOS input buffer vs schmitt ? Any reason to go for slow slew ? [11/15/2025 13:10] mole99 Is this a general question or one related to the template? - The schmitt buffer can be used for the clock to prevent false switching/glitches. But I'm not sure if it's absolutely necessary. - Slow slew: for EMC reasons for example [11/15/2025 13:16] 246tnt It was more in general but in the context of GF180. Like I don't see any case where you wouldn't want a schmitt input for instance. AFAICT from the spec document, it's same delay, same input load, so why not use it all the time ? [11/15/2025 13:18] mole99 Good point. Perhaps because it does not switch at the mid-point, which could be a problem for some applications? Just guessing 🤷‍♂️ {Reactions} 👍 ============================================================== Exported 4 message(s) ==============================================================
