============================================================== Guild: wafer.space Community Channel: Information / questions / Is there a DRC violation waiver system? After: 02/28/2026 23:59 Before: 04/01/2026 00:00 ============================================================== [03/24/2026 17:43] nmz787 Is passing DRC strictly required to tapeout? Is there any waiver system? For example I want to make topmetal "pads" smaller than design rule pad sizes, as I want to post-process dies/wafers to add additional layers to the design. [03/24/2026 18:24] nmz787 @Matt Venn your comments were helpful 🙂 [03/24/2026 18:25] nmz787 Though I assume your "yes" was in regards to "strictly must pass DRC" [03/24/2026 18:33] mattvenn I thought I was in the tt discord [03/24/2026 18:33] mattvenn Where the answer is no, but I don't know for wafer.space [03/24/2026 19:33] 246tnt For last run, they wouldn't even waive the antenna rule 😅 [03/24/2026 20:57] nmz787 that makes sense though, because of charging during plasma steps [03/24/2026 20:59] nmz787 a discharge event will cause spallation and can cover not only your wafer with particles, but the entire chamber... leading to later batches to get particle contam {Reactions} 😮 [03/26/2026 13:09] mole99 Tim wants wsrun-2 to follow the DRC rules much more strictly, as per the PDK docs. The only rule I can find for the pad layer is for the top metal overlap: https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_09_1.html All the other rules are guidelines: https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_09_2.html However, as there is no mention of a minimum pad width anywhere, wafer.space has to assume a minimum width of 40x40 according to PAD.1. [03/27/2026 06:44] mithro_ Passing DRC is strictly required for tapeout, there is no waiver system and there won't be any support for waivers. [03/27/2026 06:48] mithro_ @Leo Moser (mole99) - What about the rules @ https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_09_4_3.html and https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_09_4_5.html ? [03/27/2026 06:48] nmz787 Oh i thought 4 microns was allowed (some rule or guideline about "gold") [03/27/2026 06:48] nmz787 But that still is larger than ideal for "a via" to an additional layer [03/27/2026 06:49] nmz787 Ideally we'd know exactly the fab minimum CD limit [03/27/2026 06:55] nmz787 It looks like there's 4 different bonding processes... [03/27/2026 06:56] nmz787 Which one is offered for "bare wafer" purchase option needs clarification though [03/29/2026 05:11] mithro_ None of these bonding processes are really on offer, we are using an external wire bonding house. [03/29/2026 08:29] mole99 Unfortunately, they don't apply to our use case and specify different numbers. While the solder bump (solder ball) rules specify a min. passivation opening of 40um, the probe guidelines specify min. probe passivation opening of 50um. There's an interesting note in the bond pad guidelines: > These are just default numbers for DRC purpose only, however, these are VARIABLE and the customer is advised to use the appropriate value acceptable to their assembly house. So I suppose there's no min. limit for the passivation opening specified, because they assume that you are going to use sane numbers anyway, in order to do the bonding process. [03/29/2026 08:32] mithro_ Do you see a maximum size for the passivation opening? [03/29/2026 08:54] mole99 No, I haven't seen one. [03/29/2026 16:20] nmz787 Minimum is likely more important for the litho operating point for that layer [03/29/2026 23:01] mithro_ Well, if there is no maximum, then you could just have a completely open top of the chip with no passivation. [03/29/2026 23:08] nmz787 Wouldn't "Min Probe pad top layer metal overlap of pad opening" flag? [03/29/2026 23:10] mithro_ Dunno, that is why I was asking. [03/30/2026 08:26] mole99 Even if there's no rule against it, I'm not sure if that doesn't lead to planarity issues at any of the processing steps. ============================================================== Exported 25 message(s) ==============================================================
