Information / questions / Magic error: non-integer magnification
Hi, I was running some prechecks for a multiproject chip and it is failing at certain instance throwing this error: Non-integer magnification (0.2) in transform. Rounding to 0. Has anyone faced something similiar?, and have an idea how to solve it? Thanks, Luighi
Tim 'mithro' Ansell 12/16/2025 16:03
@Leo Moser (mole99) / @Tim Edwards - Any ideas on this error?
Leo Moser (mole99) 12/16/2025 16:04
@LuighiV can you post a link to the layout?
Hi @Leo Moser (mole99) @Tim 'mithro' Ansell this is the link https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view?usp=sharing
16:14
In the meantime I was doing some tests, and I think I found the root cause of the issue (seemed to have some empty subhierarchies inside A3) I deleted those empty hierarchies and right now I'm running the pre-checks again to confirm if those were the responsible of raising the error
Leo Moser (mole99) 12/16/2025 16:24
That's great! However I see some other issues:
16:24
16:24
The SRAMs from the default template were not correctly deleted. Their PR_bndry layers still exist and their instances can be found in the cell tree.
😮 1
16:25
The seal ring (guard ring) is missing around the outer padring. (edited)
Oh... didn't noticed it, I guessed I have deleted it completely, going to update it, thanks for noticing 🙂 👍
regarding the seal ring, do you have a Pcell or script I can use to add it?
Leo Moser (mole99) 12/16/2025 16:36
I'm adding a check to the precheck to ensure there are some shapes on GUARD_RING_MK: https://github.com/wafer-space/gf180mcu-precheck/pull/36 This way we should catch such issues earlier :)
🙌 1
LuighiV
Leo Moser (mole99) 12/16/2025 16:37
16:38
Did you create the padring using make librelane-padring?
🙌 1
yes, I have created it using that instruction
Leo Moser (mole99) 12/16/2025 16:42
Maybe you deleted it accidentally?
16:42
For me it works fine:
yeah, that's probably the reason, let me generate it again here, thanks for the advice 🙂
Leo Moser (mole99) 12/16/2025 16:43
You're welcome!
🙌 1
Hi @Leo Moser (mole99) thanks for your feeback, now the padframe has the sealring and I deleted completly the SRAM devices:
however now I'm facing an issue with DRC errors, because as I'm following the embedded approach, I use a previous padframe we were using for Chipathon, however, that padframe seems to have some issues with CUP DRC. Do you know how can I fix it? (edited)
02:40
this is the report I got:
Tim 'mithro' Ansell 12/17/2025 03:11
@LuighiV - I guess the chipathon padframe needs to be updated with the fixed cells that Leo updated for wafer.space shuttle.
03:11
In theory you should just be able to drop in a replacement?
Hi @Tim 'mithro' Ansell, thanks for the advice 🙂 . Yes, I think I can do that, I'm trying right now to update the library from Leo's repo in my environment so it could get the fixed cells. Hope it goes fine 🤞
Leo Moser (mole99) 12/17/2025 08:21
@LuighiV Yes exactly, the bondpad cells have been updated. You need to replace the bondpads in the chipathon padframe with the bondpads in: https://github.com/wafer-space/gf180mcu/blob/main/gf180mcuD/libs.ref/gf180mcu_fd_io/gds/gf180mcu_fd_io.gds Note: only the "Bondpad_5LM" cell has been changed.
Hi @Leo Moser (mole99) thanks for the comment. I've tried to replace the main pads by the new ones in your repo, however, when I run again, it is violating other rules with metal spacing, and the corner pads, have you modified them as well?
LuighiV
Leo Moser (mole99) 12/17/2025 12:42
No, I didn't modify any other cells. Did you perhaps delete some of the I/O filler cells? The errors always seem to be at the boundary of I/O cells (well, except for the corner cells). (edited)
Hi Leo, I don't think so, I mean, I haven't delete the fills, what I did was just replace the old pads by the new ones by using the Replace cell option in the Cells panel
Leo Moser (mole99) 12/17/2025 12:58
That sounds like the correct approach. Could you share the current GDS so I can take a look?
yes!, please, give me a moment
and this was the report
Tim 'mithro' Ansell 12/17/2025 13:15
@LuighiV - It would be good to load your latest GDS into the platform even if it is currently failing the precheck.
🙌 1
Leo Moser (mole99) 12/17/2025 13:19
Something happened when you swapped out the bondpad cells:
13:19
13:19
This is the top right corner of the outer padring.
13:19
13:20
And this is the top right corner of the inner padring (chipathon).
13:24
These manual edits are dangerous and error prone. How about we create a KLayout script to merge the GDS files and swap the bondpads? :) Can you share the separate GDS of the empty template project, and the GDS of the chipathon?
sure, I'm going to upload it, thanks
that would be great 🙂 , let me restore the previous version of the chipathon then, and going to share both
👌 1
Hi @Tim 'mithro' Ansell I'm having issues to upload from Google Drive. I was using this link https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view but it says it has size 0. I've tried with github but it has more than 100Mb so doesn't allow me to upload there
Leo Moser (mole99) 12/17/2025 15:16
@LuighiV Tim is currently asleep. You need a direct link to your layout. However you can compress it, if you didn't already?
that's a good point, let me try it here
LuighiV
LuighiV
It worked! thanks, now it is running the checks
Leo Moser (mole99) 12/17/2025 15:44
It seems I got it working, but there is something very strange going on, as you can see:
15:44
15:44
If I open chiptop_A_track__exported.gds I can see that something is wrong:
15:45
15:45
Normally, the design should be centered and fill the whole screen. KLayout thinks that the design is larger than it actually is?
15:45
There is this strange Axx_top cell in the cell hierarchy. If I hide it, you can see its outline:
15:46
15:47
If I open the hierarchy of this cell, there are many, many subcells:
15:47
15:47
It seems there is a second separate padring hidden inside this cell?
15:49
You need to clean up the layout, but once that's done I think you should be able to use this script:
🙌 1
15:50
Enable the Nix shell of the template project and run the following (adjust the paths): python3 scripts/merge_chipathon.py chipathon/padring_ws.gds chipathon/chiptop_A_track__exported.gds
😮 1
15:50
Hi Leo, indeed that come from one of the teams, they joined later as they didn't have a number was assigned Axx 😅 . On the other hand, didn't notice they have a second separated padring there. Let me check that, thanks for noticing 🙂
that's great! thank you @Leo Moser (mole99) going to try to clean up and run the script you provided, It will be really helpful, thank you 🙌
Leo Moser (mole99) 12/17/2025 15:56
I'm looking forward to your submission :) Let me know if there are any issues with the script.
🙌 1
sure! thank you! 🙂
Hi Leo, just to comment that in the klayout version we have in the docker image used during the Chipathon (0.30.2) I cannot see those outlines. I was able to see it just in version 0.30.4. Maybe it is in an improvement in recent versions
Leo Moser (mole99) 12/17/2025 17:52
That could very well be 👍
🙌 1
17:54
FYI, after you have merged the designs, you need to run filler generation. klayout -b -zz -r ${PDK_ROOT}/${PDK}/libs.tech/klayout/tech/drc/filler_generation/fill_all.rb -rd input=chip_top.gds -rd output=chip_top_filled.gds
🙌 1
sure, thank you for sharing it 🙂
Hi @Leo Moser (mole99) now the design passed all the checks, thanks for your help 🙂 🙌
👏 2
LuighiV
Tim 'mithro' Ansell 12/18/2025 01:46
Congradulations! Make sure you click the "Submit for Manufacturing" button!
🙌 1
Hi @Tim 'mithro' Ansell yes! I did it, thank you 🙌
LuighiV
Tim 'mithro' Ansell 12/18/2025 03:16
At the current time, it does look like there should be room on the shuttle for your design.
🙌 1
that's great! hope the possibility remains open till the end of submission time 🤞
Exported 74 message(s)
