============================================================== Guild: wafer.space Community Channel: Information / questions / Magic error: non-integer magnification After: 11/30/2025 23:59 Before: 01/01/2026 00:00 ============================================================== [12/16/2025 06:18] luighiv Hi, I was running some prechecks for a multiproject chip and it is failing at certain instance throwing this error: ``` Non-integer magnification (0.2) in transform. Rounding to 0. ``` Has anyone faced something similiar?, and have an idea how to solve it? Thanks, Luighi {Attachments} 2025-12_media/ab738aec-86e8-448c-8614-81bde0995d7c-17D71.png [12/16/2025 16:03] mithro_ @Leo Moser (mole99) / @Tim Edwards - Any ideas on this error? [12/16/2025 16:04] mole99 @LuighiV can you post a link to the layout? [12/16/2025 16:11] luighiv Hi @Leo Moser (mole99) @Tim 'mithro' Ansell this is the link https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view?usp=sharing [12/16/2025 16:14] luighiv In the meantime I was doing some tests, and I think I found the root cause of the issue (seemed to have some empty subhierarchies inside A3) I deleted those empty hierarchies and right now I'm running the pre-checks again to confirm if those were the responsible of raising the error [12/16/2025 16:24] mole99 That's great! However I see some other issues: [12/16/2025 16:24] mole99 {Attachments} 2025-12_media/image-65E3E.png [12/16/2025 16:24] mole99 The SRAMs from the default template were not correctly deleted. Their PR_bndry layers still exist and their instances can be found in the cell tree. {Reactions} 😮 [12/16/2025 16:25] mole99 The seal ring (guard ring) is missing around the outer padring. [12/16/2025 16:35] luighiv Oh... didn't noticed it, I guessed I have deleted it completely, going to update it, thanks for noticing 🙂 👍 {Reactions} 👍 [12/16/2025 16:36] luighiv regarding the seal ring, do you have a Pcell or script I can use to add it? [12/16/2025 16:36] mole99 I'm adding a check to the precheck to ensure there are some shapes on GUARD_RING_MK: https://github.com/wafer-space/gf180mcu-precheck/pull/36 This way we should catch such issues earlier :) {Reactions} 🙌 [12/16/2025 16:37] mole99 This is the PCell: https://github.com/wafer-space/gf180mcu/tree/main/gf180mcuD/libs.tech/klayout/tech/pymacros/sealring_cells [12/16/2025 16:38] mole99 Did you create the padring using `make librelane-padring`? {Reactions} 🙌 [12/16/2025 16:39] mole99 This script adds the sealring to the padring: https://github.com/wafer-space/gf180mcu-project-template/blob/01d1540414fefce2d3c8fca2086c425688fe389a/scripts/padring.py#L59 [12/16/2025 16:40] luighiv yes, I have created it using that instruction [12/16/2025 16:42] mole99 Maybe you deleted it accidentally? [12/16/2025 16:42] mole99 For me it works fine: {Attachments} 2025-12_media/image-D1640.png [12/16/2025 16:43] luighiv yeah, that's probably the reason, let me generate it again here, thanks for the advice 🙂 {Reactions} 👍 [12/16/2025 16:43] mole99 You're welcome! {Reactions} 🙌 [12/17/2025 02:19] luighiv Hi @Leo Moser (mole99) thanks for your feeback, now the padframe has the sealring and I deleted completly the SRAM devices: {Attachments} 2025-12_media/image-5C5E8.png [12/17/2025 02:34] luighiv however now I'm facing an issue with DRC errors, because as I'm following the embedded approach, I use a previous padframe we were using for Chipathon, however, that padframe seems to have some issues with CUP DRC. Do you know how can I fix it? [12/17/2025 02:40] luighiv this is the report I got: {Attachments} 2025-12_media/image-834D6.png 2025-12_media/drc1216.klayout-3228E.lyrdb [12/17/2025 03:11] mithro_ @LuighiV - I guess the chipathon padframe needs to be updated with the fixed cells that Leo updated for wafer.space shuttle. [12/17/2025 03:11] mithro_ In theory you should just be able to drop in a replacement? [12/17/2025 04:55] luighiv Hi @Tim 'mithro' Ansell, thanks for the advice 🙂 . Yes, I think I can do that, I'm trying right now to update the library from Leo's repo in my environment so it could get the fixed cells. Hope it goes fine 🤞 [12/17/2025 08:21] mole99 @LuighiV Yes exactly, the bondpad cells have been updated. You need to replace the bondpads in the chipathon padframe with the bondpads in: https://github.com/wafer-space/gf180mcu/blob/main/gf180mcuD/libs.ref/gf180mcu_fd_io/gds/gf180mcu_fd_io.gds Note: only the "Bondpad_5LM" cell has been changed. [12/17/2025 11:56] luighiv Hi @Leo Moser (mole99) thanks for the comment. I've tried to replace the main pads by the new ones in your repo, however, when I run again, it is violating other rules with metal spacing, and the corner pads, have you modified them as well? {Attachments} 2025-12_media/image-D3E87.png [12/17/2025 12:42] mole99 No, I didn't modify any other cells. Did you perhaps delete some of the I/O filler cells? The errors always seem to be at the boundary of I/O cells (well, except for the corner cells). [12/17/2025 12:57] luighiv Hi Leo, I don't think so, I mean, I haven't delete the fills, what I did was just replace the old pads by the new ones by using the **Replace** cell option in the **Cells** panel [12/17/2025 12:58] mole99 That sounds like the correct approach. Could you share the current GDS so I can take a look? [12/17/2025 12:59] luighiv yes!, please, give me a moment {Reactions} 👍 [12/17/2025 13:03] luighiv this is the link: https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view?usp=drive_link {Embed} https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view?usp=drive_link chiptop_A_track_ws_embedded__exported.gds [12/17/2025 13:04] luighiv and this was the report {Attachments} 2025-12_media/drc1217.klayout-E586A.lyrdb [12/17/2025 13:15] mithro_ @LuighiV - It would be good to load your latest GDS into the platform even if it is currently failing the precheck. {Reactions} 🙌 [12/17/2025 13:19] mole99 Something happened when you swapped out the bondpad cells: [12/17/2025 13:19] mole99 {Attachments} 2025-12_media/image-D58C7.png [12/17/2025 13:19] mole99 This is the top right corner of the outer padring. [12/17/2025 13:19] mole99 {Attachments} 2025-12_media/image-99866.png [12/17/2025 13:20] mole99 And this is the top right corner of the inner padring (chipathon). [12/17/2025 13:24] mole99 These manual edits are dangerous and error prone. How about we create a KLayout script to merge the GDS files and swap the bondpads? :) Can you share the separate GDS of the empty template project, and the GDS of the chipathon? [12/17/2025 13:29] luighiv sure, I'm going to upload it, thanks [12/17/2025 13:31] luighiv that would be great 🙂 , let me restore the previous version of the chipathon then, and going to share both {Reactions} 👌 [12/17/2025 15:08] luighiv Hi @Tim 'mithro' Ansell I'm having issues to upload from Google Drive. I was using this link https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view but it says it has size 0. I've tried with github but it has more than 100Mb so doesn't allow me to upload there {Attachments} 2025-12_media/image-DF967.png {Embed} https://drive.google.com/file/d/1GgmRQ5E_GbQYZFp6ogSY1hEyT46GxshO/view chiptop_A_track_ws_embedded__exported.gds [12/17/2025 15:16] mole99 @LuighiV Tim is currently asleep. You need a direct link to your layout. However you can compress it, if you didn't already? [12/17/2025 15:16] luighiv that's a good point, let me try it here [12/17/2025 15:26] luighiv Hi @Leo Moser (mole99) regarding this point, these are the links for : - Original Chipathon GDS: https://github.com/AutoMOS-project/AutoMOS-chipathon2025/blob/update-for-ws/designs/libs/A_track_core/chiptop_A_track/chiptop_A_track__exported.gds - Empty WS Padframe: https://github.com/AutoMOS-project/AutoMOS-chipathon2025/blob/update-for-ws/designs/libs/A_track_core/padring_ws/padring_ws.gds [12/17/2025 15:26] luighiv It worked! thanks, now it is running the checks [12/17/2025 15:44] mole99 It seems I got it working, but there is something very strange going on, as you can see: [12/17/2025 15:44] mole99 {Attachments} 2025-12_media/image-F306E.png [12/17/2025 15:44] mole99 If I open `chiptop_A_track__exported.gds` I can see that something is wrong: [12/17/2025 15:45] mole99 {Attachments} 2025-12_media/image-39653.png [12/17/2025 15:45] mole99 Normally, the design should be centered and fill the whole screen. KLayout thinks that the design is larger than it actually is? [12/17/2025 15:45] mole99 There is this strange `Axx_top` cell in the cell hierarchy. If I hide it, you can see its outline: [12/17/2025 15:46] mole99 {Attachments} 2025-12_media/image-1C535.png [12/17/2025 15:47] mole99 If I open the hierarchy of this cell, there are many, many subcells: [12/17/2025 15:47] mole99 {Attachments} 2025-12_media/image-0B3B4.png [12/17/2025 15:47] mole99 It seems there is a second separate padring hidden inside this cell? [12/17/2025 15:49] mole99 You need to clean up the layout, but once that's done I think you should be able to use this script: {Reactions} 🙌 [12/17/2025 15:50] mole99 Enable the Nix shell of the template project and run the following (adjust the paths): ``` python3 scripts/merge_chipathon.py chipathon/padring_ws.gds chipathon/chiptop_A_track__exported.gds ``` {Reactions} 😮 [12/17/2025 15:50] mole99 {Attachments} 2025-12_media/merge_chipathon-7A261.py {Reactions} 🙌 [12/17/2025 15:51] luighiv Hi Leo, indeed that come from one of the teams, they joined later as they didn't have a number was assigned Axx 😅 . On the other hand, didn't notice they have a second separated padring there. Let me check that, thanks for noticing 🙂 {Reactions} 👍 [12/17/2025 15:53] luighiv that's great! thank you @Leo Moser (mole99) going to try to clean up and run the script you provided, It will be really helpful, thank you 🙌 [12/17/2025 15:56] mole99 I'm looking forward to your submission :) Let me know if there are any issues with the script. {Reactions} 🙌 [12/17/2025 15:59] luighiv sure! thank you! 🙂 [12/17/2025 17:29] luighiv Hi Leo, just to comment that in the klayout version we have in the docker image used during the Chipathon (0.30.2) I cannot see those outlines. I was able to see it just in version 0.30.4. Maybe it is in an improvement in recent versions [12/17/2025 17:52] mole99 That could very well be 👍 {Reactions} 🙌 [12/17/2025 17:54] mole99 FYI, after you have merged the designs, you need to run filler generation. ``` klayout -b -zz -r ${PDK_ROOT}/${PDK}/libs.tech/klayout/tech/drc/filler_generation/fill_all.rb -rd input=chip_top.gds -rd output=chip_top_filled.gds ``` {Reactions} 🙌 [12/17/2025 18:15] luighiv sure, thank you for sharing it 🙂 {Reactions} 👍 [12/17/2025 21:42] luighiv Hi @Leo Moser (mole99) now the design passed all the checks, thanks for your help 🙂 🙌 {Attachments} 2025-12_media/image-5CA10.png {Reactions} 👏 (2) [12/18/2025 01:46] mithro_ Congradulations! Make sure you click the "Submit for Manufacturing" button! {Reactions} 🙌 [12/18/2025 03:09] luighiv Hi @Tim 'mithro' Ansell yes! I did it, thank you 🙌 {Attachments} 2025-12_media/image-8ED85.png [12/18/2025 03:16] mithro_ At the current time, it does look like there should be room on the shuttle for your design. {Reactions} 🙌 [12/18/2025 03:22] luighiv that's great! hope the possibility remains open till the end of submission time 🤞 ============================================================== Exported 74 message(s) ==============================================================
