    "iconUrl": "2025-11_media/fb143eaa45770cbb40493d09b625e98b-09FD1.png"
    "id": "1444531273728262376",
    "name": "Metal Fill",
    "after": "2025-10-31T23:59:59.999+00:00",
    "before": "2025-12-01T00:00:00+00:00"
  "exportedAt": "2026-05-11T18:48:36.6149147+00:00",
      "timestamp": "2025-11-30T03:31:33.75+00:00",
      "content": "When I use LibreLane to generate a small digital module, everything looks normal but there is no metal fill, whereas I noticed that the top design in the template does have metal fill. What is causing this difference?",
        "id": "839883081896689765",
        "name": "buck_042",
        "nickname": "Buck",
        "avatarUrl": "2025-11_media/1-B2132.png"
      "attachments": [
          "id": "1444531274445230090",
          "url": "2025-11_media/image-60690.png",
          "fileName": "image.png",
          "fileSizeBytes": 180369
          "id": "1444531275003203698",
          "url": "2025-11_media/image-C245E.png",
          "fileSizeBytes": 6879
      "id": "1444535127051862158",
      "timestamp": "2025-11-30T03:46:52.454+00:00",
      "content": "First thought would be different hardening strategies in the config.json, but could be wrong (https://librelane.readthedocs.io/en/latest/usage/caravel/index.html)",
        "id": "585619259888107520",
        "name": "bigturtle8",
        "nickname": "Marcus",
        "avatarUrl": "2025-11_media/c791e3f7cff7a56aa3f76777c4e5c5f4-5A2F3.png"
      "id": "1444536417509183488",
      "timestamp": "2025-11-30T03:52:00.123+00:00",
      "content": "I don't know, I don't see any configuration related to metal fill in template's config.yaml. And the fillers are successfully inserted, but no metal fill.",
        "name": "buck_042",
        "nickname": "Buck",
      "id": "1444552932862329045",
      "timestamp": "2025-11-30T04:57:37.69+00:00",
      "content": "I see, the template uses the chip flow, which calls some KLayout scripts to insert metal fill. In my case, I didn\u2019t explicitly set any flow, so I assume it\u2019s using the default classic flow, which doesn\u2019t seem to run the KLayout density/metal-fill steps.\n\nIf I want to add metal fill for a small standalone digital block, what is the recommended approach?",
        "name": "buck_042",
        "nickname": "Buck",
      "attachments": [
          "id": "1444552931838918778",
          "url": "2025-11_media/image-81663.png",
          "fileSizeBytes": 12239
          "id": "1444552932224667708",
          "url": "2025-11_media/image-6D40A.png",
          "fileSizeBytes": 25628
          "id": "1444552932581179422",
          "url": "2025-11_media/image-5CAC4.png",
          "fileSizeBytes": 16405
      "id": "1444592695732473906",
      "timestamp": "2025-11-30T07:35:37.897+00:00",
      "content": "Normally, you wouldn't run metal fill for a standalone block.\n\nOne way to do that, however, is to add the `KLayout.Filler` step after one the StreamOut steps in the Classic flow. You can do this directly in the config.",
        "avatarUrl": "2025-11_media/3c7c17f3225f6e56f4dccd83f14383f2-73F83.png"
      "id": "1444596035371532418",
      "timestamp": "2025-11-30T07:48:54.129+00:00",
      "content": "Thanks! May I ask how to do that directly in the config?",
        "name": "buck_042",
        "nickname": "Buck",
      "id": "1444623255473230096",
      "timestamp": "2025-11-30T09:37:03.907+00:00",
      "content": "You can find the relevant docs here: https://librelane.readthedocs.io/en/latest/usage/writing_custom_flows.html\nBy using `substituting_steps` and placing a \"+\" before the step ID. You're welcome!",
      "id": "1444741493037203487",
      "timestamp": "2025-11-30T17:26:53.939+00:00",
      "content": "Thank you!",
        "name": "buck_042",
        "nickname": "Buck",
  "messageCount": 8
