============================================================== Guild: wafer.space Community Channel: Information / questions / Metal Fill After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/30/2025 03:31] buck_042 When I use LibreLane to generate a small digital module, everything looks normal but there is no metal fill, whereas I noticed that the top design in the template does have metal fill. What is causing this difference? {Attachments} 2025-11_media/image-60690.png 2025-11_media/image-C245E.png [11/30/2025 03:46] bigturtle8 First thought would be different hardening strategies in the config.json, but could be wrong (https://librelane.readthedocs.io/en/latest/usage/caravel/index.html) [11/30/2025 03:52] buck_042 I don't know, I don't see any configuration related to metal fill in template's config.yaml. And the fillers are successfully inserted, but no metal fill. [11/30/2025 04:57] buck_042 I see, the template uses the chip flow, which calls some KLayout scripts to insert metal fill. In my case, I didn’t explicitly set any flow, so I assume it’s using the default classic flow, which doesn’t seem to run the KLayout density/metal-fill steps. If I want to add metal fill for a small standalone digital block, what is the recommended approach? {Attachments} 2025-11_media/image-81663.png 2025-11_media/image-6D40A.png 2025-11_media/image-5CAC4.png [11/30/2025 07:35] mole99 Normally, you wouldn't run metal fill for a standalone block. One way to do that, however, is to add the `KLayout.Filler` step after one the StreamOut steps in the Classic flow. You can do this directly in the config. [11/30/2025 07:48] buck_042 Thanks! May I ask how to do that directly in the config? [11/30/2025 09:37] mole99 You can find the relevant docs here: https://librelane.readthedocs.io/en/latest/usage/writing_custom_flows.html By using `substituting_steps` and placing a "+" before the step ID. You're welcome! [11/30/2025 17:26] buck_042 Thank you! ============================================================== Exported 8 message(s) ==============================================================
