============================================================== Guild: wafer.space Community Channel: Information / questions / Other pad frame options After: 03/31/2026 23:59 Before: 05/01/2026 00:00 ============================================================== [04/01/2026 00:40] mithro_ @Matt G. (Mobius) - As @tnt says, you need to use the default pad ring if you want the CoB add-on, otherwise you are free to do what ever you want. [04/01/2026 16:28] mguthaus Ok. What about the first part of the question? How do we generate the other pad frames? Will we have to add our own slot configurations etc? [04/01/2026 16:33] mguthaus Was there a reason that we didn't use the max IO option for the CoB? It doesn't change the core area. [04/01/2026 16:35] 246tnt The COB cost is per-bond-wire, more bond wire is more expensive. [04/01/2026 18:03] mole99 If you go for the 1x1 slot, you can simply change the `PAD_*` variables in this config: https://github.com/wafer-space/gf180mcu-project-template/blob/main/librelane/slots/slot_1x1.yaml However, you must ensure that the pad instances you are referencing exist in the RTL: https://github.com/wafer-space/gf180mcu-project-template/blob/main/src/chip_top.sv {Embed} https://github.com/wafer-space/gf180mcu-project-template/blob/main/librelane/slots/slot_1x1.yaml gf180mcu-project-template/librelane/slots/slot_1x1.yaml at main · ... Project template for wafer.space MPW runs using the gf180mcu PDK - wafer-space/gf180mcu-project-template 2026-04_media/gf180mcu-project-template-68E02 {Embed} https://github.com/wafer-space/gf180mcu-project-template/blob/main/src/chip_top.sv gf180mcu-project-template/src/chip_top.sv at main · wafer-space/gf... Project template for wafer.space MPW runs using the gf180mcu PDK - wafer-space/gf180mcu-project-template 2026-04_media/gf180mcu-project-template-68E02 [04/03/2026 00:31] mithro_ Some IO configuration experiments are displayed at https://mithro.github.io/gf180mcu-project-template/ [04/03/2026 00:32] mithro_ @Matt G. (Mobius) - As tnt said, the cost is a few cents per wire-bond, so too many IOs makes it more than the $1.50 USD budget ============================================================== Exported 7 message(s) ==============================================================
