Information / questions / Pin Placement
Hi all. I’m using the template project to PnR some small digital modules and plan to integrate them into a larger analog block. I’m not using the template configs, just the Librelane environment. I have a question: how can I more precisely customize pin locations? Is there any script or config that lets me specify the absolute position of each pin on the floorplan? With pin_order.cfg I can only spread pins evenly along one side. Any help will be appreciated.
The easiest is to the the "DEF template" feature. See FP_DEF_TEMPLATE.
20:48
Then you can write a DEF that define exact positions of the pins you want.
Thank you! Are there any DEF template files that I can use as a reference?
08:42
Tiny Tapeout above also use some and they're pretty minimal.
Thank for everyone's help!
Egor Lukyanchenko 11/30/2025 17:29
If you have an abstract LEF (for example after LibreLane run with pin placement you would like to fix) you could easily make a template DEF from it with magic, like this. (edited)
Exported 9 message(s)
