============================================================== Guild: wafer.space Community Channel: Information / questions / Pin Placement After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/29/2025 20:04] buck_042 Hi all. I’m using the template project to PnR some small digital modules and plan to integrate them into a larger analog block. I’m not using the template configs, just the Librelane environment. I have a question: how can I more precisely customize pin locations? Is there any script or config that lets me specify the absolute position of each pin on the floorplan? With pin_order.cfg I can only spread pins evenly along one side. Any help will be appreciated. [11/29/2025 20:48] 246tnt The easiest is to the the "DEF template" feature. See FP_DEF_TEMPLATE. [11/29/2025 20:48] 246tnt Then you can write a DEF that define exact positions of the pins you want. [11/29/2025 23:05] buck_042 Thank you! Are there any DEF template files that I can use as a reference? [11/30/2025 08:37] bailey8889 @Buck the caravel's user_project_wrapper uses one. https://github.com/chipfoundry/caravel_user_project/blob/main/openlane/user_project_wrapper/fixed_dont_change/user_project_wrapper_gf180mcu.def {Embed} https://github.com/chipfoundry/caravel_user_project/blob/main/openlane/user_project_wrapper/fixed_dont_change/user_project_wrapper_gf180mcu.def caravel_user_project/openlane/user_project_wrapper/fixed_dont_chang... Contribute to chipfoundry/caravel_user_project development by creating an account on GitHub. 2025-11_media/caravel_user_project-AE990 [11/30/2025 08:41] 246tnt https://github.com/TinyTapeout/tt-support-tools/blob/main/tech/gf180mcuD/def/tt_block_1x1_pgvdd.def {Embed} https://github.com/TinyTapeout/tt-support-tools/blob/main/tech/gf180mcuD/def/tt_block_1x1_pgvdd.def tt-support-tools/tech/gf180mcuD/def/tt_block_1x1_pgvdd.def at main ... Tiny Tapeout project build tools + chip integration scripts - TinyTapeout/tt-support-tools 2025-11_media/tt-support-tools-64586 [11/30/2025 08:42] 246tnt Tiny Tapeout above also use some and they're pretty minimal. [11/30/2025 17:24] buck_042 Thank for everyone's help! [11/30/2025 17:29] egorxe If you have an abstract LEF (for example after LibreLane run with pin placement you would like to fix) you could easily make a template DEF from it with magic, [like this](https://github.com/egorxe/gf180mcu-sram-wrappers/blob/main/utils/magic_def.tcl). {Reactions} 👍 ============================================================== Exported 9 message(s) ==============================================================
