@namibj - Depend on how much funds you have, you could hire @stuart to see if he can find options for you in China. He is the person who is currently helping wafer.space get the wire bonding done.
@stuart I mean I am open to consider sponsoring some searching for affordable flip-chip mounting of wafer.space dies; I'd assume there'd be more general use with attaching some modern-node 0.2~0.35 mm pitch WLCSP part to a wafer.space ASIC without the usual downsides.
Like, a small chip could fit entirely on the inside of the standard-COB-compatible pad ring.
And the otherwise usual large ESD structures could be shrunk a lot if those IOs are sealed in underfill before the chips leave high-class antistatic rooms. Nor do they need high drive current because there's no real distance to cover/wires to pick up noise.
TL;DR: any estimates on what you'd expect to need to bill for keeping an eye and ear out regarding mask less (or practically maskless, like just hiding one die edge that's filled with wire bond pads from the plating) post-metallization that would turn (part of) the die into reflow-capable LGA "packaging"?
