This layer can't abut or partially overlap between subcells is usually a contact area, and very easy to have happen to layouts not created with magic that are read into magic. The p-ohmic spacing error involves layers that magic generates automatically on output, so it doesn't see the actual layers (PPLUS and NPLUS) but infers an error from a combination of two rules and a measurement from COMP (p-tap) to COMP (nFET gate). That one seems more like an actual error but with two layers which magic doesn't even see being involved, it could easily be a false positive.
ERROR_ON_MAGIC_DRC: False for the precheck and the template. This way we run Magic DRC but do not end the flow with an exception.
We already have some false-positive CO errors in magic because some designs use the 9T stdcell library. So this might be the way forward?
-Werror, I dislike it when things warn -- either it should be important enough I care about and thus an error or it isn't important and thus shouldn't be produced.
run/<timestamp>/11-magic-drc/reports/*.lyrdb or run/<timestamp>/13-klayout-drc/reports/*.lyrdb.
