============================================================== Guild: wafer.space Community Channel: Information / questions / Running LVS for padframe After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/29/2025 20:23] luighiv Hi everyone, We are trying to run LVS checks for the PADs in gf180mcu using netgen. Not sure if others are using the same for it or maybe can suggest another tool to do it. However, while we achieved passing successfully for other circuits, for the pads (provided by GF) seems that it is no passing. We are trying with a simple test case of 4 pads, vdd, vss, asig5v and fills. What we found is that in all the pads there is an extra net which is not present (not matched) in schematic. Digging into the issue we identified that the extracted spice netlist from layout is creating diodes with just one pin exposed while the another is connected to substrate. Not sure if netgen understands VSUBS as a global net, but the anode (substrate) is being considered as floating net during the comparison. The layout also seems to have just one pin exposed, so the extraction might be OK but might require something in netgen configuration to make it work. Have anyone faced this issue?, or can provide a guidance to configure the LVS tool properly? Thank you! cc: @peterkinget {Attachments} 2025-11_media/image-5BE2C.png 2025-11_media/image-A452F.png 2025-11_media/image-65B26.png 2025-11_media/image-F0658.png [11/29/2025 21:59] bailey8889 @LuighiV I think you may have run into the issue that magic does not handle devices that are formed by layers on different hierarchies. I have LVS pass on the gf I/O cells by flattening before extracting via `gds flatglob`ing the following. ``` *Bondpad* *CLAMP_COR* *FILL* *METAL_RAIL* *NMOS_* *POWER_RAIL_COR* *_BASE* *comp018green* *diode_nd2ps_06v0_*[A-Z]* *diode_pd2nw_06v0_*[A-Z]* *mim_*_*[A-Z]* *moscap_* *nmos_*_*[A-Z]* *nmos_4T_metal_stack* *nmos_clamp_* *pmos_6p0_esd_* *power_via* *ppolyf_u_*[A-Z]* *top_route* *_CDNS_* ``` (edited to include `*_CDNS_*`) {Reactions} 🙌 (2) [11/29/2025 22:03] luighiv Hi @bailey that's great you have already managed to make it work, let me try the same here, thanks for the advice {Reactions} 👍 (2) [11/30/2025 00:07] luighiv Hi @bailey I have used the configuration you have shared, and now the difference is in the 3rd terminal of poly resistors. In layout is connected to VSS while in the netlist is connected to VDD. Do you know how to fix this? I'm using the spice model shared in the Chipathon repository {Attachments} 2025-11_media/image-84544.png 2025-11_media/image-CFECC.png [11/30/2025 08:34] bailey8889 @LuighiV The actual layout looks like it's over nwell, so `DVDD` should be the proper connection. Can you share the extracted netlist? [11/30/2025 14:27] luighiv sure, the extrated one is attached here {Attachments} 2025-11_media/sample_pads_layout-2BF8E.spice [11/30/2025 14:31] bailey8889 @LuighiV magic extracts devices at the level the occur in the hierarchy. It has problems, for example, if you add a nwell at a parent hierarchy. For the I/O cells to extract correctly, I had to `gds flatglob` all the subcells. The final extracted netlist should only include subckts for the top level io cells. [11/30/2025 14:39] luighiv Hi @bailey thanks for the heads up, I was using the set of instruction you shared before, I guessed that way will flatten he internal hierarchies, do you why it keeps extracting the subhierarchies? {Attachments} 2025-11_media/run_lvs-ED1F3.sh [11/30/2025 14:45] bailey8889 @LuighiV Looks like I missed one. Try adding ``` gds flatglob *_CDNS_* ``` [11/30/2025 15:04] luighiv oh, got it, let me try again, thanks 👍 {Reactions} 👍 [11/30/2025 16:03] luighiv Hi @bailey I re run again but seems it has the same issue, and it keeps extracting the internal hierarchies {Attachments} 2025-11_media/sample_pads_comp-8088B.out 2025-11_media/run_lvs-AC10A.sh 2025-11_media/sample_pads_layout-74415.spice [11/30/2025 16:43] bailey8889 @LuighiV I can't understand why. Are you sure that `sample_pads_layout.spice` is the most recent file? Can you check the time stamp? [11/30/2025 17:13] luighiv @bailey yes, indeed I deleted first just to be sure it is created again and not using and old one {Reactions} 👍 [11/30/2025 20:52] bailey8889 @LuighiV ``` gfs flatglob *_CDNS_* ``` `gfs` 😆 [11/30/2025 21:05] luighiv oh... sorry, my mistake going to try again, thanks for noticing {Reactions} 👍 [11/30/2025 21:21] luighiv It worked now! 🙂, thank you so much @bailey for your help! {Reactions} 👍 ============================================================== Exported 16 message(s) ==============================================================
