Information / questions / SDF annotation issues with Icarus
After 04/30/2026 23:59
ProfessorGeek101 05/14/2026 21:23
Hi everyone! I’m working on STA gate-level simulation for a GF180 LibreLane/Wafer.Space project and I’m running into SDF annotation issues with Icarus. Our post-PNR netlist is using the 3.3V standard-cell library: gf180mcu_as_sc_mcu7t3v3 The SDF contains entries like: (IOPATH A Y (...)) for cells such as: gf180mcu_as_sc_mcu7t3v3__inv_2 gf180mcu_as_sc_mcu7t3v3__buff_2 But the Verilog model I have for gf180mcu_as_sc_mcu7t3v3.v appears to be functional-only. For example, the cells only have assignments like: assign Y = !A; assign Y = A; and I do not see specify / endspecify timing blocks. Because of that, Icarus reports errors like: Unable to match ModPath A -> Y The smoke test still passes functionally, but SDF annotation is not clean. Is there a timing-capable Verilog model for gf180mcu_as_sc_mcu7t3v3 with specify blocks? Or is timed GLS expected to be done with a different GF180 standard-cell library like gf180mcu_fd_sc_mcu7t5v? Any guidance would be appreciated!
um, you are aware that you're trying to work with a third-party PDK, right? Tholin's doing excellent work, but a one-person standard cell library is going to have teething issues like this.
Leo Moser (mole99) 05/15/2026 06:10
@Tholin would probably appreciate your contribution of specify timing blocks in the repository.
By understanding is also that there's currently suspicion on the 3v3 SCL from Tholin (maybe though not the same one, but I don't see why it would not be (effectively) the same) having an issue that causes high power draw and possibly (somewhat) worse at least at/near startup. @Tholin , if you can confirm the suspicious heating happens from a cold static start (no clocks or the like!), and happen to have the taped-out GDS for me, I'd like to try getting (low-crosstalk-fidelity) PEX out of it and the get Xyce to see how it comes up during it's POR until it (hopefully) stabilizes. And see if it triggers and alarms (in particular about power draw, though I fear localized heating might be hard to figure due to the PEX likely not allowing sufficiently-functional thermal connectivity extraction) in the process of the simulation about safe operating areas and/or can at least somewhat point to where the (I presume static) current is going. If there'd be some special sequence for the external lines to follow to do the turning-on until it exhibits the suspicious power draw, please do share. I think it'd be more worth it than trying full-die ttsky26a PEX into Xyce especially given that needs me to select a project via (iirc) digital waveforms
AFAIK Tholin's current chip doesn't use his 3v3 SCL.
I am using the 5V SCL only
Ohhhh sorry sounded like you had tested (some of) it somewhere on that die already.
Tim 'mithro' Ansell 05/18/2026 18:33
I think @Tim Edwards has test deisgns with tholin's 3v3 SCL?
Exported 8 message(s)
