Information / questions / Should clone-pdk also clone 3v3 OCD SRAM if chosen as well?
We're currently using the OCD 3v3 SRAM, and we previously used our own method with git submodules to fetch the 3v3 SRAM library. With the new project template, I thought it would have its own way to clone the 3v3 SRAM, but I believe it only fetches the 3v3 standard cells with Ciel. (edited)
Never mind it seems to be another unrelated issue
2:01 a.m.
the 3v3 SRAMs are indeed properly installed
Actually I believe clone-pdk doesn't install the 3v3 SRAM libraries
4:07 a.m.
But running librelane magically copies the SRAM libraries like it was there?
Hmm strange, I believe it's just due to running an older version of ciel then
Leo Moser (mole99) 2026-06-10 6:11 a.m.
Hi, are you sure that your template is up to date? I've just run clone-pdk and can confirm that gf180mcu_ocd_ip_sram is installed.
6:11 a.m.
You should use the version of ciel that comes with the Nix shell.
It seems to be fixed on my end now I might have forgotten to re-run nix develop
Exported 9 message(s)
