============================================================== Guild: wafer.space Community Channel: Information / questions / Should clone-pdk also clone 3v3 OCD SRAM if chosen as well? After: 2026-05-31 11:59 p.m. Before: 2026-07-01 12:00 a.m. ============================================================== [2026-06-10 1:50 a.m.] .pogeg We're currently using the OCD 3v3 SRAM, and we previously used our own method with git submodules to fetch the 3v3 SRAM library. With the new project template, I thought it would have its own way to clone the 3v3 SRAM, but I believe it only fetches the 3v3 standard cells with Ciel. [2026-06-10 2:01 a.m.] .pogeg Never mind it seems to be another unrelated issue [2026-06-10 2:01 a.m.] .pogeg the 3v3 SRAMs are indeed properly installed [2026-06-10 4:07 a.m.] .pogeg Actually I believe `clone-pdk` doesn't install the 3v3 SRAM libraries [2026-06-10 4:07 a.m.] .pogeg But running librelane magically copies the SRAM libraries like it was there? [2026-06-10 4:45 a.m.] .pogeg Hmm strange, I believe it's just due to running an older version of ciel then [2026-06-10 6:11 a.m.] mole99 Hi, are you sure that your template is up to date? I've just run `clone-pdk` and can confirm that `gf180mcu_ocd_ip_sram` is installed. [2026-06-10 6:11 a.m.] mole99 You should use the version of ciel that comes with the Nix shell. [2026-06-10 7:11 a.m.] .pogeg It seems to be fixed on my end now I might have forgotten to re-run `nix develop` {Reactions} 👍 ============================================================== Exported 9 message(s) ==============================================================
