============================================================== Guild: wafer.space Community Channel: Information / questions / SRAM rules After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/28/2025 17:55] 246tnt Are the SRAM rules only valid for foundry provided cell ? What if I want to design my own memory array or dual port cell or stuff like that, can I use them ? [11/28/2025 19:12] mole99 Yes, I think that should be possible. Afaik it's not the cells that are detected, but rather the SRAM marker layer. However, as you probably know, there's no guarantee your cells will work after production, since the SRAM cells in the PDK were probably carefully designed to violate the normal core rules. [11/28/2025 19:14] mole99 In fact, @Tim Edwards already shrinked the 5V SRAM cells. [11/28/2025 19:15] 246tnt I know he did but they are still 6T cells, I'm thinking about doing the same register file that I did on sky130, or a dual port cell, or rom or other things like that. {Reactions} 😮 [11/28/2025 19:17] mole99 Yes, as long as you place the SRAM marker layer you can use the SRAM 3.3V/5V rules, as I understand it. {Reactions} 👍 (2) [11/28/2025 22:37] mithro_ When using the SRAM cells DRC rules there are normally a bunch of requirements around the layout of the cells that are not specified in DRC decks and such. [11/28/2025 22:38] mithro_ My understanding is that they can violate the rules due to the tuning to make the regular patterns print better. [11/29/2025 07:38] mole99 These rules are documented here: - https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_11_1.html - https://gf180mcu-pdk.readthedocs.io/en/latest/physical_verification/design_manual/drm_11_2.html So it should be possible to submit your own custom cells based on these rules, but there is no guarantee that they will work as expected. [11/29/2025 16:52] rtimothyedwards_19428 Since I created the 3.3V SRAM core cell myself, we'll put that theory to the test. {Reactions} 😮 (2) [11/30/2025 01:49] mithro_ Yeap! I'm interested to see how things go, I don't quite have the same pull with GF now I'm not Google. {Reactions} 😮 (2) ============================================================== Exported 10 message(s) ==============================================================
