Information / questions / sram1024x8 (OCD)
After 04/30/2026 23:59
Rob Taylor 05/03/2026 18:29
I see in the Run 1 density report that sram1024x8 (OCD) is the best density. I can't see this in the template. Is RTimothyEdwards/gf180mcu_ocd_ip_sram the source of these? are they well tested? @Tim Edwards (edited)
They're not tested at all yet.
😕 1
If you need them to be tested faster you can probably coordinate with the owner of the preliminary COBs to write a testbench?
Rob Taylor 05/03/2026 20:28
can do. who's that?
It's @Tim Edwards . He's at Latch Up conference ATM.
Tim Edwards 05/03/2026 22:05
I'll be home by Tuesday. But I don't have any packaged parts yet. Just the "for display only" bare die.
Tim Edwards
I think the idea is that, presuming you'd be somewhat tight on time around now to spend on writing that sram-focused testbench, @Rob Taylor could speed up the sram testing by communicating with you to determine how the testing could be reasonably set up in the place that you'd have to test the COBs that I assume are due in a few days (going by the others who shared their shipping timelines), and then writing that testbench for you so you'd at least not start from scratch with it even if you have to tune/adapt it a bit to your equipment in live testing/live debugging.
Tim 'mithro' Ansell 05/04/2026 02:16
@Tim Edwards didn't use the standard pad layout in his chips, so it'll probably be a bit longer before he gets packaged parts.
Rob Taylor 05/04/2026 07:15
@Tim Edwards i think just consider that there's an offer of help if needed when you need it 🙂
07:16
would like to use the OCD blocks in the next tapeout, but its no sweat if that's not tractable
Exported 10 message(s)
