============================================================== Guild: wafer.space Community Channel: Information / questions / sram1024x8 (OCD) After: 04/30/2026 23:59 ============================================================== [05/03/2026 18:29] robtaylor_52029 I see in the [Run 1 density report](https://github.com/wafer-space/ws-run1/blob/density-report/reticle_density_report.md#user-content-fnref-38-4e4d12f3ff508dfac98a29f0039cc54f) that sram1024x8 (OCD) is the best density. I can't see this in the template. Is [RTimothyEdwards/gf180mcu_ocd_ip_sram]( https://github.com/RTimothyEdwards/gf180mcu_ocd_ip_sram) the source of these? are they well tested? @Tim Edwards [05/03/2026 18:53] 246tnt They're not tested at all yet. {Reactions} 😕 [05/03/2026 20:13] namibj If you need them to be tested faster you can probably coordinate with the owner of the preliminary COBs to write a testbench? [05/03/2026 20:28] robtaylor_52029 can do. who's that? [05/03/2026 20:41] 246tnt It's @Tim Edwards . He's at Latch Up conference ATM. {Reactions} ❤️ [05/03/2026 22:05] rtimothyedwards_19428 I'll be home by Tuesday. But I don't have any packaged parts yet. Just the "for display only" bare die. {Reactions} ❤️ [05/03/2026 22:30] namibj I think the idea is that, presuming you'd be somewhat tight on time around now to spend on writing that sram-focused testbench, @Rob Taylor could speed up the sram testing by communicating with you to determine how the testing could be reasonably set up in the place that you'd have to test the COBs that I assume are due in a few days (going by the others who shared their shipping timelines), and then writing that testbench for you so you'd at least not start from scratch with it even if you have to tune/adapt it a bit to your equipment in live testing/live debugging. [05/04/2026 02:16] mithro_ @Tim Edwards didn't use the standard pad layout in his chips, so it'll probably be a bit longer before he gets packaged parts. {Reactions} ❤️ [05/04/2026 07:15] robtaylor_52029 @Tim Edwards i think just consider that there's an offer of help if needed when you need it 🙂 [05/04/2026 07:16] robtaylor_52029 would like to use the OCD blocks in the next tapeout, but its no sweat if that's not tractable ============================================================== Exported 10 message(s) ==============================================================
