Information / questions / Unmapped Issue
Hello, I am trying to use gf180 in order to run through the digital flow, however I am running into this error that I am unsure how to find information to solve. 120. Executing JSON backend. [22:01:19] VERBOSE Parsing synthesis checks… pyosys.py:60 ────────────────────────────── Unmapped Cells Checker ────────────────────────────── [22:01:19] VERBOSE Running 'Checker.YosysUnmappedCells' at step.py:1138 'runs/RUN2025-11-1722-01-17/07-checker-yosysunmap pedcells'… [22:01:19] ERROR 2 Unmapped Yosys instances found. checker.py:127 Classic - Stage 7 - Unmapped Cells Checker ━━╺━━━━━━━━━━━━━━━━━━━━━━━━ 6/79 0:00:02 [22:01:19] WARNING The following warnings were generated by the flow: flow.py:703 [22:01:19] WARNING [Checker.LintWarnings] 10 Lint warnings found. flow.py:705 [22:01:19] ERROR The following error was encountered while __main.py:189 running the flow: 2 Unmapped Yosys instances found. [22:01:19] ERROR LibreLane will now quit. main.py:190 It appears that I can find them in: runs/RUN_2025-11-17_22-01-17/07-checker-yosysunmappedcells but the only information I get from it is I have 2 unmapped instances, nothing about what it is. Could someone point me in the right area to fix this?
Leo Moser (mole99) 11/18/2025 07:24
Hi, I assume you made changes to the template? If so, which changes did you make? If those two unmapped cells are the SRAM macros: To remove the SRAM macros, you need to remove the instances from the RTL, the config.yaml and the pdn_cfg.tcl.
Exported 2 message(s)
