============================================================== Guild: wafer.space Community Channel: Information / questions / Yosys check errors found After: 10/31/2025 23:59 Before: 12/01/2025 00:00 ============================================================== [11/18/2025 19:44] _luke_w_ I had this message, failing in stage `08-checker-yosyssynthchecks`: ``` 39 Yosys check errors found. ``` Grepping for `error` in my yosys synthesis log didn't show any likely-looking errors. I eventually realised that 39 was exactly the number of bidi pad data pins I'd not yet bothered to connect (early hacking!) so my issue is solved, but next time I get this message, how do I find the actual errors? Is `yosys-synthesis.log` the wrong place to look? [11/18/2025 20:33] aedancullen They are buried in `yosys-synthesis.log` (grep for "Executing CHECK pass") and also seem to appear separately in `reports/pre_synth_chk.rpt` (in the same yosys-synthesis step of the flow) It is definitely confusing that the 08-checker step produces the error but isn't the producer of that file {Reactions} 👍 [11/18/2025 23:06] _luke_w_ Weird, I did see the CHECK output but nothing obvious under there. Anyway thanks, I know where to look next time. Familiar name by the way 😅 {Reactions} 🙂 [11/19/2025 02:45] _luke_w_ had to dig in a little more because I have a check.rpt saying: ``` Found and reported 0 problems. ``` And a state_out.json saying: ``` "synthesis__check_error__count": 1 ``` Seems like the actual source for that log lint is here: https://github.com/librelane/librelane/blob/2bf4f4a399da9d41fbef24814cd7946bf9692ead/librelane/steps/pyosys.py#L50-L92 {Embed} https://github.com/librelane/librelane/blob/2bf4f4a399da9d41fbef24814cd7946bf9692ead/librelane/steps/pyosys.py librelane/librelane/steps/pyosys.py at 2bf4f4a399da9d41fbef24814cd7... ASIC implementation flow infrastructure. Contribute to librelane/librelane development by creating an account on GitHub. 2025-11_media/librelane-2ADA1 [11/19/2025 02:46] _luke_w_ which got me the correct error (which should really be fatal in yosys!) ``` Warning: Wire $paramod$053944574b759a0e3f2ebe9134306bd1be3bd197\twowire_dtm_core.\ndtmresetreq is used but has no driver. ``` [11/21/2025 23:56] mithro_ @LukeW - Did you end up getting this one solved? [11/22/2025 00:37] _luke_w_ yep, I know the things to grep the log for now 🙂 ============================================================== Exported 7 message(s) ==============================================================
